71 Cuda fuel line mounting
ScottG
Chattanooga, TN
I have found some great pictures out there of the fuel line mounts for a 71 Cuda that uses the 3 fuel line setup (3/8 supply, return and vapor line). All the pictures have shown the clip arrangement in the passenger rear wheel well, and under the floor pan behind the torsion bar cross-member. I haven't found anything good showing if/how the lines were secured to the front frame rail though and how they were secured to the bottom of the trunk pan as it goes across to the gas tank sender. Does anyone have any good pictures of those areas?
Thanks.
Scott
70chall440
Western Washington
There are little clips that snap around the line/s and then on the other side they have a kind V type arrangement that gets inserted into a hole (like 1/4" or smaller). The clip is made of spring steel, so when it is pushed into the hole it stays in there via tension. I don't know if the clips are remade or not
