727 BB valve body casting and part numbers
tullm
Herndon VA
I spent a little time looking through the parts manual for numbers related to valve bodies but got a little lost. I'm trying to find casting/part numbers for 727 valve body used with a 440-6 engine. I may be assuming incorrectly that the valve body would be different depending on the engine size and HP?
Any help appreciated.
Thank you
M.
I already mentioned this in one of your "reversing the reverse valve body" thread. seek out the part number of your existing transmission. the number is in the form:
PK0000000 0000 0000
and is stamped into the left side of the case flange just above the oil pan, and is about 1/4-inch high.
That PK number correlates with the part number in the dealer parts book.
transmissions wear out. and on a 50+ year old car, it's possible the transmission was rebuilt and/or serviced by a shop sometime in its history. For same-day service, it was customary to swap out the whole transmission when a repair was needed. Don't be surprised if your transmission is not the exact one the car was shipped with.
The one in my 1970 440 car is PK3410672
Any 1970 727 valve body would work perfectly. Other valve bodies from 67-73 can be made to work with slight modifications (which would be included in a shift kit I mentioned in your other post).
You can even use a 904 valve body, but you need to modify the center rear mounting bolt and the parking rod. Go this route only if you can't find a 727 valve body.
