73 barracuda rally dash wiring question.
Flathead31coupe
Indianapolis
I was wondering if anyone was familiar with the rally - wiring, I've got a couple of connectors that I'm not sure where they go.\n The one yellow wire by itself comes from the light. That shines on the heater controls.
Then there's a red plug with a dark blue and light green single wire plug on each side of it. Then there is a black plug with 2 large dark green wires, a light green wire and a dark Brown wire.\nIt also has a lighter Brown single wire with it.By itself. Thanks.
That helps out a lot, so it looks like mine is a non. A car, so the big red plug and the blue and green wire would not go to anything. And the plug that is next to the\nHeater control that has the pink wire coming from it.I do not have that one either.That must be something to do with AC.Maybe
The A/C harness is separate from the main dash harness, if you don’t have A/C, should be able to remove it altogether.
