accessory on fuse block (70 Cuda')
sharkycuda
Hi guys,
I need your help!
I was working on my 70 Cuda', and I was checking the voltage at the accessory blade on the fuse blocks. This was with the key in the run position. I only read 10.6V on my volt meter. I believe it should read 12.5 +/- Volts.
Can anyone tell me what might be happening? Thanks in advance.
-Sharkycuda
Bad wiring, bad connections at bulkhead are the most likely culprits
I won't start about the ammeter... :)
