Carter AVS Idle Issues
EMIKOL
Carter AVS Idle issues
Sorry about the long post but didn’t want to waste anyone’s time suggesting things I already tried. 1970 Challenger RT 440 4 barrel with Auto and AC. LA built CA car with ECS. Using Carter AVS 4740S. EBay carb from years ago and had it rebuilt but would never idled correctly. Very erratic and with low vacuum, unless idle speed increased and ran off the transition circuit (say >1100 RPM). Bought an edelbrock 1813 800 AVS Thunder carb. Idled well right off the bat without issue.
Recently pulled engine to address a few issues with the car. Checked cam timing. Confirmed centerline at 108, confirmed intake and exhaust lift, duration 219 deg, and confirmed cam timing at .050 for intake and exhaust. Valves were OK and compression OK all cylinders.
Went through the carb. Cleaned out all the passages and jets, confirmed the idle circuit passages were clear. Found out someone blocked off hot idle vent passage. Removed primary booster assembly and confirmed flow through passages. New gaskets. Floats checked for leaks and needles changed, floats set to spec. New accel pump plunger and adjusted, Everything was set to spec.
Back on car. Tried timing anywhere from 5-18 deg advanced. Some better at 15 deg so left it there. Kept vacuum advance hose clamped down. Once RPMs go above 1100 or so it runs great, but no stable idle can be found below 1000. Erratic Vacuum about 6-8 at idle. Raise idle speed above say 1050 or so and it runs well but now on transition circuit. Vacuum around 20. Seems to go from 1100 (Stable) to 750 or so (rough), but can’t get it to settle in between when adjusting idle speed. Doesn’t much matter where the idle mixture screws are unless in too far in and it stalls out. Seems to want more fuel. Partly covering the air horn with your hand speeds up the car while idling and runs smoother.
Thought perhaps vacuum leak. Checked everything I could. Changed carb manifold gasket and sprayed carb cleaner all around, made sure manifold (rear) and ported (front) vacuum passages were blocked off. Clamped off power brake booster with no noticeable changes. Heads to manifold gaskets fine.
Thought the secondary throttle shaft was a bit loose, So, reaching, drilled and placed brass fittings (3/8” primary and 5/16” secondary). Noticed someone had been through them before and probably didn’t have the throttle plates correctly aligned. Believe the primaries plates were on backwards and weren’t sealing well. Numbers facing toward the idle adjustment screws. I know they have tapered edges. Removed and were then oriented correctly, kept them loose until they “self-centered” as I opened and closed the throttle shafts. Got the best fit I could and really looked pretty good. Also checked the bottom of the carb with a straight edge.
Back on the car. Little to no improvement. At this point I am thinking this early emissions carb has an idle circuit that is just too lean for this setup. Cam has reasonably long duration but specs aren’t too crazy. Only issue is the idle. Runs great once off idle.
Read about blocking off part of the By-pass or idle bleeds in the low speed circuit, or even enlarging the low speed jet to get more/richer fuel mix at idle. Before I do anything I may regret, I wanted to throw it out there for suggestions.
Your camshaft is actually pretty big compared to a stock camshaft. One trick to get better idle at lower rpms is to drill a small hole in each primary throttle blade. This will let in a little more air at idle. If you don't have a set, get some numbered drill bits and start with a #45 and see if it's any better. Then you can slowly increase the hole diameter until you're happy with the idle speed. 750 to 850 rpm at idle in park would be great.
Not knowing to much about that carb. But I know something about carb operation in general. I was reading through you statement. Sound like you want to use that carb. A change in the primary metering rods might might be in order. If that might be fix. Someone here might know. I think EXCUAME is correct about the cam. I was thinking the same. Just my 2¢. There are some very good builder here.
The Carter AVS 4740S is a 1970 Mopar four-barrel carburetor primarily used on 440 cubic inch engines in B-body and E-body vehicles (such as the Dodge Charger, Plymouth GTX, and Dodge Challenger), often configured for automatic transmission with or without air conditioning.
Key Details:
  • Applications: 1970-1971 Dodge 440, 500, R/T, Super Bee, and Plymouth GTX/Satellite.
  • Availability & Pricing: Used cores typically range from $60 to $265, while professionally remanufactured units can cost up to $1,395.
  • Rebuild Kits: Genuine NOS Mopar zip kits (PN 2933198 or 3549274) are available for this model, fitting a broad range of 1969-1971 AVS carbs including the 4616S through 4968S.
  • Performance: Rated at 630-750 CFM, it features a tuneable spring-loaded secondary air door and is compatible with AFB-style metering rods for performance tuning.
Any update? Did you measure the metering rods between the two carbs?
One thing I did do is change the springs holding the metering rods down at idle, but did not change (or measure) the metering rods. It may have helped somewhat as they were popping up a bit.
But I think I found the larger problem. I noticed that when I clamped off the breather hose that goes to the air cleaner, the idle smoothed out, at least somewhat. I had checked the PCV valve assuring it was not stuck open. But I believe the spring in it is calibrated to a higher vacuum which would normally keep it mostly closed at idle. With the low vacuum the PCV valve is seeing at idle with this cam, it mimics the lower vacuum state that is seen when you step on it. The PCV valve is supposed to have high flow during that time, but not so much when it is at idle. Basically, the open PCV valve at low vacuum during idle acts like a vacuum leak, pulling air in through the breathers, through the engine, out the pvc and into the carb. Didn’t know the PVC had this kind of staged function. Not sure why this issue would not have affected the Edelbrock carburetor as much. Think the idle jets are larger, allowing more fuel in.
I see that there are some adjustable PCV valves, or that some people just put a breather on the pcv side and eliminate the PCV valve altogether. But I would like to find a PCV that fits and is calibrated for a camshaft that has low vacuum at idle. Does anyone know of a supplier for this or a part number that would work?
Probably gonna go there. Seems crazy to me that nobody makes a cheap PCV valve that has a small spring in it for low vacuum cams. Would think that would be a good selling item. Trying to preserve a stock look.
Not enough demand for such a PCV. The ME Wagner adjustable PCV is the ticket even though it does not look "correct", it will function perfectly for your engine setup! I like it so much I put one on each of my two classic cars.
