Correct water pump question
fasterfaster!
Colorado
I am in need of an original water pump for a 1970 Dodge Challenger 383 magnum. The one I have part # 2843290 seems to be about a 1/4” short of lining up with the main shaft pulley and alternator. I can only think this is the incorrect part for the engine.
Your help is greatly appreciated.
themechanic
Moore, OK
FYI, FBBO has more daily readers. Maybe get your answer there.
Make sure you have correct pulleys.
cuda joe
nj
this is my 71 cuda 383 pulley is different hope it helps
The above picture is with AC , the original post is for non AC .
A simple spacer behind the pulley could solve the problem ,even just 4 or 8 flat washers of equal thickness .
themechanic
Moore, OK
You can buy shims to help align the pulleys. There's a part number stamped in the OEM pulleys. Use the web and see if yours are correct for your 383.
Dodgeboy
Winnipeg Manitoba, Canada
I would space it out with washers, pullies look the same as what I had on my '71 383. Is your crank balancer stock? I had a aftermarket balancer that pushed the crank pully out 1/2 farther
