I bought a 70 barracuda a couple years ago and did a frame up restoration. Marked everything before the teardown as well as I could. Just before the teardown the engine ran terrible, not sure why. Assumed it was the carb.Now that its all back together with a new carb its acting the same as it was.
I have to floor it just to get it to start and it will only stay running for 20 sec or so and dies the second I let off with a loud flaming backfire out the carb. Now I'm thinking something with the ignition or coil or resistor might be incorrect, but not sure how to check because its not the same as the wiring diagram in the repair manual.
After searching for similar problems i found a bunch of threads with most of the answers way over my head.
With the ignition on there is 11v on bith terminals on one end of the resistor and 2v on both of the other end.
Any help would be great.
Rick
Rick
