Horn Issues.
cv70chall
South Florida
I recently completed a rebuild of a 70 Challenger. Everything went well except that I have a horn issue. Horns work asa normal, but they also work when pressure is applied to the steering column (pressing down on the wheel).
I would like to know how easy this is to remedy?
the horn wire must be bare or pinched somewhere between the buton & steering wheel or down the column , you can pull the wheel & crush unplug the switch can & raise the switch to check the wiring inside the column
