i just joined the group,,
gaddy 69
west point ga
i'm installing a msd 6al and need a hot wire from the switch can i use the old positive wire that went to the + side of the coil
NoCar340
Upper MI
Welcome!
To answer your question: No. That wire comes from the ballast resistor and is only full 12V+ during cranking. It's also excessively noisy, electrically speaking. You can tap off the 12V+ side of the resistor itself.
Welcome from Panama .
you want the blue wire at the ballast that is constant 12v switched .
