Oystercopy
- Joined
- Jul 25, 2019
- Messages
- 138
- Reaction score
- 49
Has anyone discovered an ignition switch that is well made, aftermarket? This will be the 3rd one I've put in this car, and it appears that most of the aftermarket switches have one problem or another. I just put this one in less than a year ago, but I've always noticed that it does not always want to stay running after I start it, which is the case here again tonight. It seems the key just has to be in the "right" position for it to stay running, which is so damn irritating. I've noticed that it will crank, but not always run until I let the key go fully to the idle position, which I know is not correct. I know it should start and then run, but doesn't always until I let the key fully back. That tends to indicate that there is a disconnect inside the switch somewhere. I hear from mechanics all the time that they will put in 5 parts until they find one that works right, which is just unbelievable to me.
Anyway, thanks for any advice.
OC
OC
