looking for Longer wheel studs 1/2 20, .673 knurled 2 inch
SFEbody
Los Angeles CA.
Hey folks, the new Ridler wheels I have need a longer wheel stud. Question is, does anyone have a source for 1/ 20 .673 knurled in 2" inch length? I HAVD SEARCHED EVERYWHERE and keep coming up with only .625 or .680 knurled. Any help is appreciated
put a nut on them , trim them with a chop saw or angle grinder , taper the ends at about 20* by hand & thread the nut off , this should remove any remaining debris .
GreenOnions
Amelia Island
I had a local machine shop cut mine. On mine the knurl sizes were different front to rear, you might want to check yours to see if they are the same/different also. Check the proposed cut length front to rear as well if you want the same amount of net thread protruding from the rotor/axle. There may be differences in the rotor vs axle thicknesses, and the backside recess(s) where the stud head seats.
SFEbody
Los Angeles CA.
Last question. Will I need to modify the holes to accept the .675 knurl Vs the .673 knurl? Or will they just press in
SFEbody
Los Angeles CA.
Hey Moparleo, good question! The Ridler wheels I am putting on only allow the lug nut to screw on the current studs about 5/16" I read somewhere it needs to be at minimum 1/2"
