REM
Camarillo, CA
Hi all, new member here and owner of a '70 Cuda 440. Bought it three years ago with the intent to change the color from yellow to black so it looks like the one I had when I was 17 way too many years ago. It is currently in the paint shop and while there I'm taking the opportunity to do some modifications to the motor (would not be doing any of this if it were a numbers matching car). Going to a 512 Stoker with Paxton Supercharger...….
I will post some pic's of the process as it goes along.
440rush
Indiana
Welcome, Looking forward to the pictures. Sounds like it's going to be a beast.
fasjac
Arkansas
Welcome from Little Rock! That sounds like lots of fun!! Looking forward to some pics. Glad you’re here!!
WDO72
Welcome from California! Good luck with your project. Sounds fun!
340challconvert
Parsippany, NJ
REM
:welcome: to FEBO from New Jersey
Can't wait to see what you do with your Cuda!
REM
Camarillo, CA
Thanks everyone for your welcome. The subframe connectors have already been done as well as narrowing the rear axel 2 " on each side to fit the 10" wide Keystone Klassic wheels.
Here are a couple of pics of before the resto-mod
I will be posting a list of items for sale that are being replaced as part of the resto-mod
REM
Camarillo, CA
List of parts for sale all came off a 1970 E Body Plymouth CUDA 440 and all in good condition. Please contact me for price and questions or any additional information
Radiator
Radiator Cap
Radiator Hose (top)
Radiator hose (bottom)
Heater Hose (inlet)
Heater Hose (return)
Water Pump Housing
Water Pump
Alternator 1 wire
Voltage Regulator
Distributor
Coil
Plug Wires
Heads
Rocker Arms & Rockers
Valley Pan
Cam, Lifters, Push Rods
Pistons & Rods
Set of NEW 440 Source 30 over pistons
Oil Pump
Timing Chain and Gears
Timing Cover (Chrome)
A833 4 Speed Manual Transmission
Drive shaft (recently balanced)
Z Bar
Flywheel
Clutch/Pressure Plate/Release Bearing
Rally Wheels/Trim Rings/Center Caps & Tires (15")
Dana 60 Rear Axle shafts (Strange Brand)
Edelbrock Intake Manifold (single plane)
Edelbrock Carb (600 cfm)
Edelbrock Carb (750 cfm)
Holley Carb (dbl pumper)
Stock Head Lights
Steering Column & Shaft (Parts Only)
Round Edelbrock Air cleaner (Chrome)
Oval Air cleaner Black with Chrome stipes (New)
Knock Out
Fantastic
Love it
Are you sure that will get you enough horsepower?
