oil in clutch area
Lee W.
Newcastle Ca.
photo of oil on trans & pressureplate
Lee W.
Newcastle Ca.
very light oil at where the main meets the oil pan. most or the oil splatter on the bell housing is on the clutch side of the flywheel . is it possible for oil to leak out the nose of the tranny behind the splines?
fasjac
Arkansas
It is. There should be a seal behind the retainer sleeve. I would replace just because you’re already there.
fasjac
Arkansas
As you know, time for a pressure plate, disc, t/o bearing etc, I would have the flywheel machined as it appears to have hot spots. If you see any hairline cracks, then replace the flywheel. The rear main is easily accessible while everything is apart. Just good insurance
fasjac
Arkansas
You can do it. It’s in the back of the sleeve.
Check the end play of the input bearing. It it’s extreme, it could be time for tranny work. Did you hear any excessive bearing noise while driving?
fasjac
Arkansas
I would suggest downloading the factory repair manual. It’s free at mymopar.com
Good to have if you don’t have a hard copy on hand.
Lee W.
Newcastle Ca.
I already have new ACT clutch & pressure plate also the flywheel was heat cracked so I bought a new one. Just did not want to put all that in and get oil on them. you suggested rear main seal. do i have to pull the pan to get to it?
fasjac
Arkansas
That’s no problem. The manual is so helpful to have at your finger tips.
Well I have often seen oil leak down from the oil line or pressure sender at the rear of the block so check there
To have oil leaking from the rear main seal it is virtually impossible to get to the other side of the flywheel & contaminate the clutch & oil coming out of the trans would get onto the clutch but the trans would be low on oil very quickly .
I am not sure what you have for an engine in front of the trans but that diaphragm clutch is not doing its job at all , it has been slipping a lot to have heat spots everywhere like that !
Really you need a new unit & might be able to save the flywheel depending on crack depth etc . I have had far better success with 3 finger clutches , I usually buy from McLeod as this is the factory style & the pressure can be controlled better using various amounts & pressure coil springs , they even have street twins if you have a 512 stroker with massive tq output for example .
Do the front trans seal yourself , it is easy to change just remove the 4 bolts & slide the retainer off & change the seal , make sure you use a sealant on the bolts when you put them back in so no oil seeps through the treads .
Lee W.
Newcastle Ca.
I finally got around to changing the clutch, pressure plate & fly wheel. Clutch & pressure is from ACT. Engine is a 440. my new problem now is when I slip the clutch to take off slowly it is real grabby & chatters until full out. is there a brake in procedure to follow or am I in Trouble again?
