Plug and play
jbearden
Has anyone ever used a Painless harness or an American Auto Wire set up?
Yes , I have installed both painless & Ron Francis , painless is a name not the install 4 days of wiring typically if you move fast
If you want Plug & PLay try Year one , M&H harnesses
jbearden
Do they work as stated?Worth the money and time?Any pros and cons to mention about them?I don't really care about going the cheapest route,but the best route.Thanks for commenting
Yes the Painless & Francis system works , it is based on GM wiring more than Mopar so you will eliminate a lot of the wires as unnessisary , you have to cut & terminate every wires as it doesn't come with plugs or sockets for the lights etc . I still prefer to use the factory wiring it is plug & play. painless uses relays for more of the circuits more like modern cars do .
