Rear sway bar bushing help
Cuda525
Working on 1973 Cuda with original rear sway bar want to replace the bar to body bushings and end linkS. What the deal on those bar to body brackets all welded together how do you replace the bushings and who’s a good source for bushings?
Grady Cain
NW Connecticut
As far as I know, the rear sway bar bushings are not serviceable and OEM replacements are not sold. I have not seen any split-type aftermarket bushings available anywhere either. Classic Industries is now offering a rear sway bar bracket 1970-1974 All Makes All Models Parts | MM8143 | 1970-74 Mopar E-Body Rear Sway Bar Bracket | Classic Industries but there are no pictures so I have no idea what is included. Based on the price, I would say it is just the bracket that mounts to the frame of the car and would have to be welded to the bushing loop.
https://photos.imageevent.com/adamell/wiperparts/websize/DSC00339.JPG
I had to drill the welds to remove the petrified bushing, but I found generic urethane bushings online for about $20. I added a zerk fitting and drilled a hole through the urethane because I wanted to avoid squeaks. It was an easy matter to weld back together. It works great and was cheap...
Here is a similar item as an example:
Sway Bar Bushings Polyurethane 7/8-inch 1974-1985
Note:this is an example, I only guessed the size at 7/8 (it may be 3/4) because I do not remember the actual size. Now given this example you could tack the brackets onto your sway bar, or discard them and re-use your originals; I would also consider buying un-split bushings and carefully cutting it, because it would be very difficult to force the bushing over the eye...
VANDAN
Just a somewhat related question here, Will the original rear sway bar set-up from a T/A, or AAR fit on a '70 R/T with Dual Exhaust ? I wasn't sure, since they were made to put on with the unique duals on the Road Racers. I put together the complete set for my R/T, but never got around to hanging it, maybe this year...
rklein71
Amarillo Texas
Many non TAA and AAR e-bodies came with a rear sway bar with dual exhaust. My 71 Cuda had one back in high school and I put a rear sway bar on my 71 Barracuda that I have now with full dual exhaust out the rear valance.
Orangedog70
That part from Classic Industries has been discontinued.
pschlosser
Santa Rosa, California
To get the old bushings out, you gotta grind away the welded parts of the housing. Presuming you can find replacement bushings, you weld the housing back around the new bushings. To be honest, it isn't often these need replacing, so if yours are only partially worn, you may want to rethink doing it.
If you're not too serious about keeping it factory looking, an aftermarket sway bar with serviceable bushings may be the way to go.
NixDad
Township of Polk, Wisconsin
So...here is a thought I had, the rear bushings appear to be a slightly shorter version of the front bushings.
Can you buy front bushings and shorten them? For a clean cut, i've frozen rubber so it cuts more easily.
You'd still be into the whole process of drilling out the spot welds and rewelding though.
