JunkYardFind
Finally finished the video that shows my Ammeter conversion to a Volt meter! It's pretty cool, the conversion turned out great! Check it out here on our JunkYard TV YouTube channel ....
			As GTX said above is correct.The amp gauge is not the problem. In a perfect world I would keep the amp gauge. No loose,corroded or overloaded connections any where.All of the vehicle loads-alternator output does NOT flow through the ammeter as originally designed, only the battery charging/discharging current should be registered
