stock brake rebuild on 70 challenger w factory disc brakes
340challconvert
Parsippany, NJ
Starting to rebuild the front brakes on my A66 challenger.
Car has been sitting since 1984.
Purchased Centric brake calipers and will clean up the factory 2 piece rotors.
Also looking at Centric brake master cylinder. These are rebuild units. I heard I should stay away from Duralast at Autozone due to quality issues.
Anyone use the Centric parts on a rebuild?
I will keep the original parts for a future rebuild and just want to get the brakes working for now.
Feed back appreciated.
js29
lee center ny 13363
I have always used Wagner brake part's. I never had much luck with A rebuilt master cylinder, I like new units myself.
340challconvert
Parsippany, NJ
Leo, Took your advice , picked up a new Raybestos brake master. The Centric masters were all rebuilds. If my original 2 piece rotors prove to b uncutable, Raybestos also makes the hub-rotor units @ 130 per. Would like to use my originals if possible.
challenger6pak
I have stored the original 2 piece rotors from my 6 pack cars. There are no reproduction 2 piece rotors that I know of.
340challconvert
Parsippany, NJ
Brake Rotor Choice for stock 70 disc brake Challenger
I was looking at the Raybestos replacement rotors.
Part Number: 7008R, not original style but should fit w/o any changes to the stock 1970 disc brake spindle.
Does anyone know what brand Jim's Auto parts sells (BR-1283) for 170.00 each? Listed as American made.
Appreciate feedback, been away from working on cars for awhile and it seems tougher to get quality stock parts.
Good question. Im sures Jim's AP does not have them made, and anything he sells is usually way over priced.
challenger6pak
Most likely the same rotors that are sold at most auto stores.
340challconvert
Parsippany, NJ
Looked up the Centric brake rotors, purchased them at $72 each. I will install and keep original 2 piece originals in storage. Tks Leo
340challconvert
Parsippany, NJ
new centric rotors
Just received the Centric Rotors. Everything matches the 1970 specs. They also have nice reinforcing ribs on the inner hub. Pics of the brakes before teardown. Sitting for a long time!
340challconvert
Parsippany, NJ
Brake parts install Washer needed w new brake lines into caliper?
Rebuilding the brakes and front end.
So far: Centric brake rotors w new Centric calipers. Happy w the rotors, fits the smaller 70 style spindle w new Timken bearings (no fitment problems)
Purchased new upper control arms with ball joint and bearings (Goodmark-looked like same quality as originals) Nice easy install new control arm bolts/nuts.
New brake caliper hoses Raybestos BH35017 with the nice plated ends.
Question: installing the new brake lines on the caliper end; Is there a brass washer that should go into the caliper at the install? NO washer came w the lines.
340challconvert
Parsippany, NJ
MoparLeo You were correct regarding the quality of the Centric Parts. It was a good recommendation.
Does anyone know what the difference is between the Inline tube full brake line set w disc brakes with 1 piece front to rear vs 2 piece front to rear? What is the difference?
Feedback appreciated
js29
lee center ny 13363
Copper 2 of them, one on the top of the banjo bolt and one on the caliper side. should have been in with the caliper, check the box. some times the little bag they are in will slide behind the flaps in the box. if you look closely the washers are probably froze to ether the fitting on the hose or to the caliper on one end anr the bolt on the other.
AUSTA
PERTH WA
I just replace all my lines with stainless inline set you need to tighten the lines a bit more than normal to seat the stainless flares as every connection leaked .
2 piece set is for vehicles with a rear brake delay valve about 2 foot from the proportioning valve roughly under where the door hinge and is bolted to the inner rocker panel helps prevent rear brake lockup
