Oil bidness
My 70 Cuda has the following issue with respect to the turn signals.
All lights front and back illuminate. The brake lights illuminate. The emergency flashers work properly. I can make the parking lights and tail lights flash by moving the turn signal lever up or down intemittenly, mimicking the action of the turn signal switch. When I engage the switch the indicator on the dash lights up but does not flash.
Suggestions on what to check next before just diving in and changing out the turn signal switch?
I assume the emergency flashers and turn signals are on the same flasher switch (which I have changed).
I know there is a fuse for emergency flashers, but is there a separate fuse for turn signals? If so, would they illuminate at all if the fuse was blown.
d
d
