Unisteer Rack & Pinion Units
moparnut74
Hello. Has anyone installed one of these units ? How do they perform in a small block Barracuda for a street car ??? :glasses2: Thanks!
Very well. Installed one in a 73 Challenger a few years ago. Has a 360 crate and TTI headers. Eliminates a bunch of conventional front end parts like : inner & outer tie rod ends, idler arm, pitman arm, steering gear box, center link, old style power steering pump. Also installed Magnum Force upper control arms. KYB shocks. Welded lca reinforcement plates from Mancini Racing. Drives like a late model car.
racer939393
did you have` a problem with the linkage binding and not able to turn steering wheel on mine where the steering column u joint goes on the rack and pinion. my is at such a angle can not turn wheel
