Vinyl top question
gtxno1
Freehold N J
Hello everyone just picked my project question is the vinyl top is in great condition been in a garage for 22 plus years I have noticed a tiny bubble on each side lower rear of the glass has anyone out there tried to gently lift to perform a repair to the area and reglue those areas thanks
moparlee
Mid Michigan
If you haven't already, remove the bottom glass trim piece and do a close inspection of the area the glass sits in. My guess is that there is more corrosion in that area. Usually 50 yr old vinyl is pretty dry and will crack if you mess with it.
Are you doing a full restoration or just getting your car road worthy? If just doing maintenance to have a safe driver, I would leave the vinyl top alone.
