What distributor is this?
BillJ
Costa Mesa, CA
This is on a 318 I am putting in my Cuda. Bought engine on Ebay.
Also I am leaning towards the Pertronix system. Want a sanitary engine compartment but it looks like there have been negatives about all the systems. Thank you.
Also I am leaning towards the Pertronix system. Want a sanitary engine compartment but it looks like there have been negatives about all the systems. Thank you.View attachment 158609
The pictured distributor is a stock type single magnetic pick-up Chrysler electronic ignition distributor used from late 1971 through 1987 in non-Electronic Lean Burn or non-Electronic Spark Control applications.
For more information about the Chrysler electronic ignition system, see
Thank you... any input on upgrading it? I want something reliable (of course) and sanitary...
Clean it up, and leave it as is with stock Chrysler, or select good aftermarket, parts. Upgrades could include a modified advance curve to match any engine changes, and possibly premium parts such as an alkyd distributor cap with brass contacts. Other potential electronic control units (ECUs) or ignition coils are described in my linked document.
Thank you. I went and looked at your site. I appreciate the effort you put into it and it's going to keep me busy a while. I once read that when the internet first started no one anticipated that people would use it help other people!
Overall the factory system is very reliable , carry an extra ballast resistor of course & use a good quality 4 pin ECU , parts are readily available unlike aftermarket systems
The stock electronic ignition is very reliable. I've had no luck with that at all.
The Pertronix system, and the Mallory Unilite distributers are completely self-contained units. You don't need the control box or the ballast resistor (provided you have a matching coil). Distributer, coil, wires, that's it.
I've had good luck finding used Unilite units on eBay, clean them up, lube the shaft and run, they're built well.
If you use Perronix , make sure the Dist has 13v at all times , , the coil feed drops to 7v when running & the unit Will fail quickly
I’ve used the Pertronix I setup on one of my cars for 15 years and well over 31k miles and it has worked flawlessly. I converted my Challenger from points to Pertronix I at the same time where it worked just as well for thousands of miles. When I rebuilt the engine and replaced the engine harness I figured I’d switch to the factory style electronic ignition and ran into nothing but troubles with all the post production garbage that’s been available all these years. I regretted switching away from the Pertronix I system on that car to this day even though I finally got parts that work on it now. I have heard some negative feedback about the Pertronix 2 & 3 systems but the standard system is easily the best aftermarket part I’ve ever put on any vehicle I have ever owned.
