SpeedD408
I need to replace the window felts on the drivers side of my 71 Cuda. I took the door panel off and with the window all the way down, I think I can get to all but 2 maybe 3 screws holding the outside felt on. Is there a trick to doing this with the window installed or do I need to pull the window out? I'll probably do both inside and outside felts as why not when you are this far in, but was hoping to not need to remove the window. Reason, I've never done it before and not sure how to put it back in and get everything in alignment.
