gran coupe john
Broke wire on starter relay is there a way to get wire out of plug without messing it up.
Terry where did you get these tools?Yes. I use the tools in this photo to remove the wires in the plastic housings. I use the flat pronged ones to depress the tang on the wire connector and slide it out of the plastic housing. You could probably make one out of a thin piece of stiff metal like an old jewelers screwdriver. You will need small needle nose pliers to pull it out after tang is depressed. If you have to do alot of wires, the tools are nice to have. The round ones on the multi-tool work for the round ones in steering column plugs.
Terry W.
