Flchallenger
440 stroked to 500 inch with a MSD ready to run distributor. Have 13.5 volts at coil, and wire leading to dist. No spark coming out. Checked coil it checks across the terminals at 2 ohms. When it is turning over I am losing all voltage at coil? No ballast resistor Any ideas. could it be shorting out. Before this started car overheated and all fluids against the coil and distrubtor. This has a march pulley system and the theromastat gasket blew out and sprayed the motor with a nice stream of steam at the end. Lovely day.
