Thanks. I'll take a look at it tomorrow.Typical factory installed 14" Rallyes were 5.5" or 6" wide.
With the wheel off of the car you can feed a tape measure through one of the oval shaped holes in the center of the wheel and measure the rim width easily. But 7" were not available as standard.
The outer lip adds .5" to each side, so a 6" wide wheel is 7" when measured from outer lip to outer lip. So, measure the outside dimension and subtract one inch.I have 14 inch Rallye wheels. What is the best way to measure the width of the rim without removing the tire? I need to order beauty rings but I need to know if the rim is 6 or 7 inches wide. Thanks
Thanks, that,s good to know.The outer lip adds .5" to each side, so a 6" wide wheel is 7" when measured from outer lip to outer lip. So, measure the outside dimension and subtract one inch.
Yes. It looks like it's 6in wide. ThanksEasier when the tire is off. You said the tire is still mounted, correct ? Did you measure and find out what you needed?
