no back brakes
i have 70 chall drum brakes replaced wheel cylinder went to bleed brakes and no fluid will flow out of both lines what could be the problem?
Proportioning valve or a problem in the rubber hose down to the diff where the inner layer is broken down & blocking flow , you need to crack the brake lines & see how far the fluid does flow
thanks for the info.
