Yes, heads on the inside and nuts to the outside.I have always had the nuts in the engine bay & the heads in the wheel well .
It makes it easier to do the alignment. Crack the nut and tighten back up. Just piss off the alignment guy and you get a bad job.Yes, heads on the inside and nuts to the outside.
Thanks that helps a lotJust found this in the FSM. View attachment 96001
Years ago, I WAS the "alignment guy"! I never did a bad job though, too much riding on my work.It makes it easier to do the alignment. Crack the nut and tighten back up. Just piss off the alignment guy and you get a bad job.
