Camber bolts
Ricky J
Hi just wondering does it matter which way the camber bolts are fitted .Bolt head from engine bay side or vice versa.
Thanks in advanced for any help.
rklein71
Amarillo Texas
My pictures of my 71 BHG before disassembly shows both adjusting bolts having the nut on the outside. Don't know if it makes a difference though.
Ronbo73
Dudley, MA
If I remember correct, when I removed my upper control arms, I could not get a ratchet in the upper control arm wheel well area to loosen the bolts. I could only fit the ratchet through the access panels and a wrench in the upper control arm wheel well area. I think that is the reason for the orientation of the camber bolts.
