Windage Tray on 340 - Use the original or go with new Milodon windage tray with new larger Milodon oil pan? Is there a difference?
Mr Cuda
North of Seattle
Is this the road race pan thats gated?
I have the milodon U weld it gated pan kit, that I was going to use on my next motor, but it has a full T head shape.
autoxcuda
Los Angeles
No. That’s the “Low Pro”. It has the notch in middle to create a higher spillover wall during acceleration. That feature was used in the road race pan too.
p/n 31590 for 340
Milodon Road Race Oil Pan
Mr Cuda
North of Seattle
Your right, it was moroso.
It looks just like that once I welded it together. I just havent put it on a pan yet.
The biggest clearance problem would be fixed by long pitman and idler.
I expect that pan would be $800 if the other one is mid $500
autoxcuda
Los Angeles
$614 from Mancini
The curve of K-member rear lip creates wide pan issues.
Really so in A-body 73-76 K-member applications I help test fit it on.
As much pan as possible!! :
73-76 A-body K-member
Mr Cuda
North of Seattle
This car is so modified, that the final fit of engine/pan suspension/k member will be on the table. So cutting the K is no problem.
marksmopars
Mancini makes a replica of the original which faithfully replicates the original design for the windage, fyi.
SRKlegin
Roy, UT
Awesome. I was able to recondition the original tray, have the crank cap bolts both are in great shape, but am curious is to what type of bolts will screw to the cab bolts. Anybody ever change them out?
SRKlegin
Roy, UT
$614 from Mancini
Looks like you used header wrap to protect the starter/wires. Are your headers ceramic coated as well? I just got my set of Doug Thorley headers. Motor is still at machine shop. Did you have to loosen your engine and raise it to get your headers in?
autoxcuda
Los Angeles
I put the headers in at the same time as the motor. But it was in an A-body. So tighter engine compartment than an E-body. And I run a 73-76 Spool type motor mount K-member that even tighter. With this 73-76 K-member in an A-body, the motor can only be put in without the trans connected.
SRKlegin
Roy, UT
I got it cleared through the wife and the new tray and hardware are on their way. Better piece of mind. Thank you for your help!
