TBI upgrade
skipjack99
Fond du Lac
I have a 71 Cuda with a 383 that I am going to rebuild and plan on upgrading the fuel system to TBI, any thoughts on which systems are any good or ones to avoid?
rmchrgr
Stamford, CT
Holley Sniper or Terminator X, wouldn't consider anything else. I'm on my 3rd Holley EFI conversion with my Challenger. There's a huge online community for support and tons of aftermarket accessories out there now to expand it's functionality. Holley just recently rolled out a Bluetooth module too. Terminator X has more options within the ECU (it's also a separate box from the throttle body itself) but you my not need that level of capability. Sniper 2 has a Power Distribution module thing now which makes wiring connections easy. If you have decent mechanical and wiring skills it's fairly easy to install with the Sniper being the easiest.
You should also be comfortable with using a laptop and software in the car - things like navigating through screens, saving and retrieving files, filling in blank fields, right-clicking options, etc. If you can't do that kind of stuff in 2025 'cause "you're not a computer person", are scared of or don't trust them, forget it and stay with a carb.
That said, the tuning ideas are the same as a carburetor and mechanical distributor but they are represented and ultimately manipulated through programming. Holley does provide little 3.5 screens to monitor things but they are borderline useless when it comes to making tuning changes. A laptop will be your friend.
It's also important to be aware of the fact that a lot of buyers get roped in by the advertising and hype. I've seen it first hand and it never ends well. If you think it's just a couple easy hours in the garage and the car will run perfectly without ever having to lift a finger, save your money and stick with a carburetor. Do your research, there's more to it than meets the eye.
Here's a few things to keep in mind before pulling the trigger. Be honest with yourself here.
  • It's not magic so be willing to put the time and effort into tuning the thing beyond the initial install. Garbage in, garbage out.
  • It is a significant investment of money and time which will seem way worse if you end up yanking it out in frustration.
  • Buy the whole package as it's designed to work that way - ECU, ignition box/distributor, in-tank fuel pump, etc. That means don't cheap out on certain components (especially the ignition) as you will never achieve the full potential of the system.
  • If you're starting from scratch, it's best to have all new (modern!) wiring and have a good grasp of how Chrysler electrical systems function. Mopar is a little different than the Brand-X stuff which can present unique issues to get around.
  • If you half-ass stuff (especially the wiring) you WILL have problems. Do things right (which may include critical thinking and/or creativity) and take pride in your craftsmanship.
Hope that helps.
rmchrgr
Stamford, CT
@rmchrgr
Nice detailed and well balanced response. :thumbsup:
Thank you.
For whatever reason, I tend to respond a lot of EFI questions on forums. It's probably because there's still a lot of misconceptions about it and it's fun to dispel myths. I've done a few of them and know what it takes to make them work. I am in no way an expert and have a lot to learn myself but I enjoy that aspect of it. I'm a believer in these systems but not a crusader. I'm not going to get wound up about what's better. Carburetors will always have their place and EFI is not for everyone.
The advertising does make it seem like the greatest thing since sliced bread but the reality is these things come with certain caveats that can easily make you want to blow up your car. Plus, people are stubborn about what they think they know and often tend to mistrust or bad mouth things they don't know or understand. Such is life.
Again, I've witnessed that kind of uninformed buyer scenario first-hand with a neighbor of mine so it's not hyperbole. This guy saw that I put a Sniper on my old '68 Coronet and decided he wanted it for his Brand-X big block cruiser. Problem was, he was not the right type of guy to do it since he is not particularly hands-on. He'd had cars for years but he was not the guy to be bent over the fender every Saturday afternoon. His car also needed a lot of work before it was wise to even consider an EFI conversion. There's often unexpected costs involved beyond the initial EFI package purchase especially if your car is still original or ratty or both. Again, garbage in, garbage out. EFI can't fix intake or exhaust leaks, gummed up valves, incorrect timing or what have you.
One day soon after I go over to his place to look at his ride and tell him what I thought. Above all, the wiring was beyond shot. All the textbook maladies were there. The main battery cable was literally hanging on by one strand of copper, not to mention twist'n'tape situations and random quick splices everywhere for god knows what. Compounding that was the fact he had no idea how bad it actually was. It was surprising that the car hadn't burned to the ground.
I suggested he re-wire the car or at least re-do the obviously butchered parts of it and he looked at me and said why? I'm not sure if he could see it my face but I was pretty much dumbfounded. Despite that glaring red flag, I offered to help him do it. Of course "he knew what he was doing" though so I said OK and left. You can tell where this is going.
After that I didn't hear from this dude for a while. As you'd expect, he ignored my suggestions and went ahead with the install on his own. Needless to say, the car wouldn't start and he called me up asking for help. I made a few general suggestions over the phone and agreed to stop by and give it a look knowing it was going to be an indecipherable mess. I went but didn't do or say much since I had no idea what he did or didn't do except for being fairly certain he didn't read the instructions at all.
He kept messing with it for a while with no luck. After a few weeks of aggravation, he called me again and said was yanking the whole thing. I talked him down out of the tree and told him not to give up. After many hours on the phone with Holley tech support he finally got it running but unfortunately that's as far as it went.
I know for a fact the guy never got involved with tuning it either. After he had it running, I offered to "give him a known good tune" and would walk him through the process of loading it into the ECU. One day he dropped his SD card off on his way to somewhere else so it surely wasn't happening then. Regardless, it was pretty clear that he had zero interest in learning how to load the tune and was essentially expecting me to do it for him. He said he'd come by soon but never did.
A few months later I found out through another neighbor he moved out of town. That was in 2023. Out of the blue a few months ago I got a call from him asking for the card thing back. It had been almost two years after he dropped it off the first time. He came by and I gave him the card but haven't heard from him since. Frankly this guy should have saved himself all the aggravation and hassle and just stuck with his carburetor but I suspect he had no clue how to tune that either.
The point here is to go into this stuff with your eyes open and be realistic on how involved you want to get with it. They're great if you put the time into them but are an expensive clusterf*ck if you don't. They are not going to fix a poor running engine so put the time into optimizing what you have already and then decide if it's worth doing.
MoparCarGuy
I wholeheartedly agree with everything that @rmchrgr posted. This is not for the faint-of-heart and should only be done on a car that is fully-sorted out.
The Holley Sniper systems can do almost anything you want but I would not buy a system with the ECU in the throttle body. The Terminator X Stealth system, as noted by @rmchrgr has a separate ECU which can be installed in the interior of the car. The harness is long enough to locate your ECU and the Hyperspark 2 ignition box inside the car. I installed my ECU under the driver side dash under the cowl area and the ignition box on the lower firewall at the center of the transmission tunnel. Here is a good article from 2017 on the Terminator X Stealth system.
Here are few of the things that must be reworked to properly do an EFI conversion. Some were mentioned by @rmchrgr but I will just list my thoughts to cover the bases.
Research - Study everything you can to learn about EFI so you do not make the mistakes others have made the hard and costly way. EFI Systems Pro is a great resource and has unbelievable tech support both before and after an installation. The Holley forums are also invaluable.
Fuel System - Holley regulator with an EFI fuel tank, in-tank pump, fuel filter, and a full return line to the tank (do not cheap out with an inline pump and no return). This thread has some good info on fuel filtration and fuel system.
Electrical System - Upgrade to at least a 100-Amp alternator (Powermaster one-wire with internal regulator) and the Holley power module (these are a newer development and solve lots of power issues). All wiring should be properly thought out and routed accordingly. Buy the proper size loom coverings and make it look professional. You need to get this done properly the first time around as you will never make time to redo it.
Time - The installation is NOT a "let's do it this weekend" project. It can be done but I would take as much time as necessary to get this right. The last thing you want to do is install everything and then spend an inordinate amount of time troubleshooting why it would not start or has other issues, e.g. radio frequency interference to your sensor inputs, etc.
There is so much to research and consider so good luck if you choose to take this on. Remember, if it was easy, then anyone could do it.
skipjack99
Fond du Lac
Hope that helps.
Thanks for the response, I have been fleet mechanic for almost 40 years and agree with every point you made!
I was leaning towards the Sniper but they don't offer a distributer to pair with this engine
rmchrgr
Stamford, CT
They actually do but they call it a Hyperspark distributor. It's basically an MSD distributor with a hall-effect trigger wheel inside.
Definitely get the EFI ignition stuff. A lot of guys cheap out and skip those parts because the system will still work without them but only in a limited manner. Half the benefit of EFI is controlling timing which is not possible with a regular distributor.
https://www.holley.com/products/ignition/distributors/hyperspark_distributors/parts/565-305BK
Holley also sells an entire ignition kit. The ignition box says Sniper on it. The newest version is smaller than the one I have.
https://www.holley.com/products/ignition/distributors/hyperspark_distributors/parts/565-305K
My response was for the less hands-on guys thinking about doing an EFI conversion. If you're someone who doesn't know how to wire a relay or crimp things properly or identify a switched 12v source you're going to struggle. If you've been a tech for any length of time you should be able to handle the install without too much hassle. Nothing about these systems requires real advanced skills but if you can't be a lazy dummy either.
I was a Chrysler tech for a little bit, they drilled wiring and electronics into us. I have the background, tooling and the patience to make my own harnesses (because the supplied ones are useless) but most guys aren't going to get that involved with it.
This is from my Duster that is equipped with a Terminator X system. In the pic I'm about halfway through building an un-terminated flying lead harness. I made dedicated buss connectors for the sensors, separate ones for the B+ and switched 12v stuff and the grounds. I used a Deutsch connector to pass everything through the firewall. I used an MSD solid state relay for the fan, water pump and fuel pump. The aluminum shelf thing bolts to the inner firewall. (street/strip car, no heater).
This is the finished product which includes all the normal dash wiring as well. Took a while to get to this point but it's in the car.
Not saying everyone needs to get this deep into these systems and I don't recommend it either, it's not worth the effort for a weekend toy. I'm a glutton for punishment though...
skipjack99
Fond du Lac
skipjack99
Fond du Lac
Super cool! that was my plan all along, there is no way I would trust a wire harness that is over 50 years old, all of this would be upgraded to better wiring with the water tight connections and better grounds. Any type of ecu driven component needs to have a good power source and a good reliable ground in order to work properly, garbage in garbage out
rmchrgr
Stamford, CT
Get the 440 distributor and use adaptor to run it in your 383.
I'm not sure why you'd want to do this, there's no point. In general, you wouldn't use a mechanical distributor with EFI anyway so you'd actually be wasting $70 for an irrelevant part.
Far as I know, the only reason those adapters exist is if someone decides to go from a RB to a low deck block and does not want to spend the money on a low deck distributor. The OP is starting with a 383. Holley makes a Hyperspark distributor for that application so just get the correct part to start.
Thanks. It was a bit of work but that's really the way to do it. I'm on my third go around with this same job on my '72 Challenger. After fighting with it on two prior cars I know what to do now so hopefully it takes less time.
I'd love to see Holley or some vendor make a dedicated EFI harness for our cars. As I mentioned already, the harness they supply in their kits is difficult to work with at best. I learned a lot by taking them completely apart and redoing them to fit in my cars properly but I don't need to prove to myself that I can do it again...
At the very least, Holley should offer their EFI customers the choice of whether to purchase or include a generic harness when they buy an EFI kit. The flying lead harness is not an insignificant expense on top of the initial purchase especially when the supplied harness just gets thrown back into the box.
That said, I always suggest re-wiring a car even if it looks OK and regardless of whether EFI is involved or not. You are correct in saying that 50-year old wiring should not be trusted. Insulation gets brittle, terminals get corroded, etc. Not to mention the Mopar bulkhead connector is the worst. It seems silly to take a chance on OE wiring after investing the money in one of these EFI systems because when it starts causing problems (it will) you're going to be re-doing it all anyway. Just start fresh and never worry about it again.
I'd bet that most people don't think about that idea before making a retrofit EFI purchase and likely wouldn't want to get involved with that job anyway, even if presented with the pitfalls of not doing it. Re-wiring a car is a big, involved job especially if you replace the OE harness with a modern one. In the end it will yield a better result and cause less hassle though so it's a good idea to factor that into the overall cost of the job.
One thing to be aware of is that the Sniper can be susceptible to RFI. Supposedly the Sniper 2 safeguards against it to some degree but I'm not sure how they quantify that. Either way, it's just something to be aware of. Thoughtful wiring and shielding where necessary should mitigate most of it.
I chose the Terminator X for my Challenger because the ECU can be mounted inside the car which effectively eliminates the chances of RFI affecting it. It's a more expensive and complex system though so there are pros and cons to both systems.
I found out the hard way that there's actually more room under an A body dash than there is in an E body. I was surprised but the area behind the E body firewall is very tight especially if you still have a heater box. If choosing the Terminator take some time to think about where you want the ECU and how the harness will route to it's various terminations. There are not many practical spots to put it if you want it to remain out of sight. Sniper would be easier to install for sure, the wiring less involved.
MoparCarGuy
The Stealth throttle body has the same height as a Holley double-pumper carb.
Your shaker will work fine if the intake manifold height is stock or within 1/2-3/4” taller than stock.
I run an Edelbrock Performer RPM intake and a modified fiberglass shaker baseplate. It uses a Moroso drop-base air cleaner bottom which is bonded to the modified fiberglass shaker base. Looks quite stock.
rmchrgr
Stamford, CT
Cool, nice job. I like the Stealth throttle body myself. The Sniper kind of looks odd to me so thankfully it was under the air cleaner. Most people didn't even realize it was EFI unless I took off the air cleaner.
This was the drop-base air cleaner that I used on my '68 Coronet. Not an E Body Shaker but you get the idea. This was a basic Performer intake so not taller than stock. Just have to be aware of the feed lines and fittings going into the throttle body. The front was pretty close but it cleared after a couple whacks with a hammer on the inside edge. I use Aeroquip Push Lok hose and fittings. I have some XRP and Russell fittings too.
I assumed they made a 440 as it's more popular for conversions. Obviously if they make one for the 383, use it. 🙂
Personally, I still love my Thermoquads and factory electronic distributors because I grew up tuning them for my needs. But that seems to be a fast fading lost art.
Oh, and yes, the 440 distributor is about 1/2" longer and the adaptor would not interfere with the hood. But sounds like they make the correct distributor!
MoparCarGuy
Details on the Shaker base "drop-base" modification for higher intake manifolds like the Edelbrock Performer RPM 440. Works to lower your Shaker to proper height and get the correct
movement!
Fiberglass baseplate and adapter ring. Xstream K&N filter top (need the airflow). Bottom only of a Moroso drop-base air cleaner (order black if you can).
Use "elevator bolts" cut-to-length to attach the drop-base to the Shaker baseplate after you mark and cut out the fiberglass.
Mockup and example elevator bolt (Amazon or maybe even Lowe's specialty hardware section).
MoparCarGuy
Yep, Holley makes the Hyperspark 383 distributor. $499.95 (JUL2025) for distributor only and $961.09 (JUL2025) for the
Sniper EFI HyperSpark 2 Ignition System - CHRYSLER 383 / 400 - Black Part # VK020305BK
with the distributor, coil, and the Hyperspark 2 ignition box. You can probably find better pricing fr9om other vendors (Summit/Jeg's/EFI Systems Pro).
The new ignition box is about 1/2 the size of the first version that I have. I chose the satin black distributor.
