jackn440
For those of you who haven't read my last post, i have a '70 Challenger with a newly rebuilt 383. 4 bbl Carter 650, 727, mild cam, hogged out stock intake, headers, hei distributor (the kind that just runs off of the voltage regulator). At first i was having issues getting it to stay running when it reached operating temp, which i discovered was due to excessive coil heat. After replacing the coil, it no longer stalled when it reached operating temp. I have been driving the car around every day for the last week or two. For the first couple days it ran fine, and then started to get a mild stumble when lightly accelerating. It seemed like the longer i drove the car (throughout the day, long enough for it to build more heat), the worse it would get, to the point of stalling. The baseline idle is set at 1000 rpm out of gear and 800 in gear. I noticed that when this problem arises, it doesn't want to idle in gear at all, even if i hold it at 1000 with my foot. So when i come to a stop light, i have to pop it in neutral, at which point in runs fine, accept for the fact that the idle has increased to around 1200 rpm. If i put it back in gear, it goes back down to 800, and then continues to run poorly until it dies. I pulled a plug and it looks fine, not black or white, just slightly used. I don't know whether to blame this problem on vacuum or what, but if you guys have any ideas, please throw them my way. Thanks.
