Front hood lip trim and rear trunk lip trim.What besides the mirrors and bumperettes ?
That's what I'm looking for.What besides the mirrors and bumperettes ?
rear bumperettes dodge challenger - Bing images
Thanks rbbruno. After my family, this car is the next coolest thing I have ever done in my life. I love driving it. I have almost accomplished my three main goals that I set 4 years ago of having the car look nice, drive nice and sound nice. I don't know if a car like this is ever "done" but it's getting close.Nice job Bill, you should be proud of your work
Yup... That's EXACTLY what mine is doing other than when I run a separate ground to the switch and a separate ground to the motor it still will not go to park. I'll will hopefully get it figured out today. Thanks for the video Leo. Helps a "ton"!Here is a video, It sounds like the switch and ground. The switches are made to rebuild easily.
mopar 73 dodge challenger 3 spped wiper switch repair - Bing video
The red wire spade connector on the molex plug at the firewall plug was pushed through to the inside not allowing electrical contact to be made on the red wire. I ran a separate wire to ground from the back of the switch base plate, fixed the firewall terminal and now it works as it did when it came off the line in 1973 (very cool stuff!). On to the next project of running a separate wire from the radio all the way back to the battery positive terminal before my shut off switch. When I turn the switch off in the trunk the radio looses all of it's settings and I need to reset all the stations, treble, bass, etc... every time I go to turn the car on with the battery switch. There is a separate wire they want you to run direct to power all the time and another through the ignition circuit. Don't worry, I will put a fuse at the battery lolYup... That's EXACTLY what mine is doing other than when I run a separate ground to the switch and a separate ground to the motor it still will not go to park. I'll will hopefully get it figured out today. Thanks for the video Leo. Helps a "ton"!
Run radio wire direct to battery. "Check".
Wire trunk light. "Check". (cool how the light socket works when the lid is opened)
The punch list is getting smaller!
It's a weird feeling driving by the local NAPA and thinking "I don't need to buy anything form them today"! lol
Thanks Mike. Any help would be great. I purchased some steel yesterday and have something in mind but it would be nice to see what others have done.I have seen a thread where someone has added extensions. They were also very simple. Will try and dig up something.
Mike
Bill,Thanks Mike. Any help would be great. I purchased some steel yesterday and have something in mind but it would be nice to see what others have done.
