djlackore
- Joined
- Jun 4, 2016
- Messages
- 64
- Reaction score
- 3
Okay guys,
So I have a 73 with a 440 at trans. Things I have replaced:
Coil
Starter relay
Ignition box
Ballad resistor
Voltage regulator
All new dash harness
Dimmer switch
Hi beam switch
Ignition switch
Turn signal switch
So mostly everything works on the car but these:
Turn signal indicators
Brake indicator
Hi beam indicator
Tach- probably burned out
So with all new dash wiring from year one how could the indicators not be working??? There is a ground wire connected to the cluster. Cluster is a rallye cluster. All the signals work on the outside of the car.
Thanks for the help in advance!!
Coil
Starter relay
Ignition box
Ballad resistor
Voltage regulator
Dimmer switch
Hi beam switch
Ignition switch
Turn signal switch
Brake indicator
Hi beam indicator
