6 Cylinder vs V8 front Disc Brakes
money pit
I have a 70 Barracuda with a slant six. It has front disc brakes. I'm installing a 360 in it. Is there a difference between the braking systems? Do I need to replace the calipers and rotors? I have 14 inch ralley wheels. If I do have to do a conversion, will I need to get larger wheels? Thanks
Your brakes will be fine. Having disc brakes is a plus as too.
Thanks that's good to hear. This car is really becoming a money pit but I'll never sell it.
If you would like to go up one step, consider upgrading your existing disc brakes using stock Mopar parts from 73-74 e bodies, 73 on b body and 73-76 A body parts. This swap allows you to use the 11.75" mopar police rotor. (which are readily available, not like our current two piece 70 rotors)
Your stock disc brakes are fine, especially with the small block (less weight over the front wheels) and no big changes are really necessary.
The key with this upgrade is to use the correct steering knuckle to maintain correct suspension geometry.
Check out this Ehrenberg article.
DISC-O-TECH: Stop on a dime from Mopar Action and Rick Ehrenberg
For my brake rebuild, I kept it simple, rebuilt the front end with mostly stock 1970 parts, bought new 1 piece replacement rotors that had support ribs in the back with the smaller inner bearings and upgraded to larger tie rods. I do have a list of stock Moog front end part numbers if you need it.
Good luck with your money pit!
(They all are, but we still love them)
Thanks. I'll take a look at the article. Appreciate your help.
Since that article was writen, there is more knowledge about brakes. You can without trouble use the newer 73 up B brakes. Money pit, I would research it and come to your own conclusion, since it is still a controversal subject.
Sorry for the late reply. Thanks. I looked at the article. a lot of good info.
For reference: I believe all challengers use the same disc brakes for the year - ie. the disc brakes on a 1970 slant six would be the same as a 1970 440 car.
I agree in the factory service manual there is only one set up for the 1970 Challenger, another way to confirm would be to cross reference the brake pad part number to see which cars they fit I bet the slant uses the same pads as a Hemi.
Thanks, that's good to know. This car is a money pit, as my name implies.
A Ford can get expensive too. Especially a big bock.
Body is the worst if you ask me. I hate it and it cost so much to have it done correctly it's crazy! The aftermarket sheet metal doesn't fit very well so you need a good body man, and that ain't me!! LOL
Make sure to do a full brake inspection. Meaning front to rear including all hoses, hard lines ( dents, dings, rust) lining, springs, cylinders (seepage, leaks, stuck pistons) master cylinder (sediment, leaks). Completely drain and flush with fresh, new fluid. This is standard maintenance for all brake systems, not just 40 + year old brakes.
That was the plan since the rear end I got had the lines exposed. I plan on replacing all the steel lines and junction blocks and wheel cylinders. The plan is to go to rear discs.
I totally agree but I am probably the worst offender just lazy I suppose, but annual brake fluid changes are a great for preventative maintenance even if you don't use the car the fluid absorbs moisture which causes damage to everything changing the fluid is cheap and easy compared to repairing the damage the moisture can cause.
