    Dismiss Notice
6 Cylinder vs V8 front Disc Brakes
Brakes
  1. money pit
    money pit Well-Known Member
    64
    6
    Nov 17, 2017
    I have a 70 Barracuda with a slant six. It has front disc brakes. I'm installing a 360 in it. Is there a difference between the braking systems? Do I need to replace the calipers and rotors? I have 14 inch ralley wheels. If I do have to do a conversion, will I need to get larger wheels? Thanks
  2. hellrats
    hellrats Member
    23
    Nov 30, 2018
    Your brakes will be fine. Having disc brakes is a plus as too.
  3. money pit
    64
    6
    Nov 17, 2017
    Thanks that's good to hear. This car is really becoming a money pit but I'll never sell it.
  4. paharamia
    paharamia Well-Known Member
    2,321
    945
    Feb 13, 2011
    Parsippany, NJ
    If you would like to go up one step, consider upgrading your existing disc brakes using stock Mopar parts from 73-74 e bodies, 73 on b body and 73-76 A body parts. This swap allows you to use the 11.75" mopar police rotor. (which are readily available, not like our current two piece 70 rotors)
    Your stock disc brakes are fine, especially with the small block (less weight over the front wheels) and no big changes are really necessary.
    The key with this upgrade is to use the correct steering knuckle to maintain correct suspension geometry.
    Check out this Ehrenberg article.
    DISC-O-TECH: Stop on a dime from Mopar Action and Rick Ehrenberg
    For my brake rebuild, I kept it simple, rebuilt the front end with mostly stock 1970 parts, bought new 1 piece replacement rotors that had support ribs in the back with the smaller inner bearings and upgraded to larger tie rods. I do have a list of stock Moog front end part numbers if you need it.
    Good luck with your money pit!
    (They all are, but we still love them)
    • Like Like x 1
  5. money pit
    64
    6
    Nov 17, 2017
    Thanks. I'll take a look at the article. Appreciate your help.
    • Thanks! Thanks! x 1
  6. challenger6pak
    challenger6pak Well-Known Member
    3,553
    540
    Feb 27, 2011
    Since that article was writen, there is more knowledge about brakes. You can without trouble use the newer 73 up B brakes. Money pit, I would research it and come to your own conclusion, since it is still a controversal subject.
    • Agree Agree x 1
  7. money pit
    64
    6
    Nov 17, 2017
    Thanks. I'll take a look at the info.
  8. paharamia
    2,321
    945
    Feb 13, 2011
    Parsippany, NJ
    Here's another perspective on the use of later E/B brake components in possible upgrades for our early e-bodies as well as other ideas
    Mopar musclecar brake upgrade | AR Engineering
    People here have a good knowledge base on many topics and are always happy to answer questions and make suggestions.
    Good luck with what you decide to do.
    • Like Like x 2
  9. money pit
    64
    6
    Nov 17, 2017
    Sorry for the late reply. Thanks. I looked at the article. a lot of good info.
  10. rolling_thunder
    rolling_thunder Well-Known Member
    60
    12
    Mar 2, 2014
    For reference: I believe all challengers use the same disc brakes for the year - ie. the disc brakes on a 1970 slant six would be the same as a 1970 440 car.
    • Like Like x 2
  11. money pit
    64
    6
    Nov 17, 2017
    Thanks for the info.
  12. aussiemark
    aussiemark Well-Known Member
    787
    205
    Nov 29, 2014
    Perth Western Australia
    I agree in the factory service manual there is only one set up for the 1970 Challenger, another way to confirm would be to cross reference the brake pad part number to see which cars they fit I bet the slant uses the same pads as a Hemi.
    • Agree Agree x 1
  13. money pit
    64
    6
    Nov 17, 2017
    Thanks, that's good to know. This car is a money pit, as my name implies.
  14. aussiemark
    787
    205
    Nov 29, 2014
    I know the feeling Mopar parts are rare and damn expensive, GM and Ford guy's got let off easy.
  15. hellrats
    hellrats Member
    23
    Nov 30, 2018
    A Ford can get expensive too. Especially a big bock.
  16. money pit
    64
    6
    Nov 17, 2017
    If I knew how to do body work and Upholstery it wouldn't be as bad. That has been the major cost.
  17. hellrats
    hellrats Member
    23
    Nov 30, 2018
    Body is the worst if you ask me. I hate it and it cost so much to have it done correctly it's crazy! The aftermarket sheet metal doesn't fit very well so you need a good body man, and that ain't me!! LOL
  18. moparleo
    moparleo Well-Known Member
    4,605
    441
    Oct 17, 2011
    Make sure to do a full brake inspection. Meaning front to rear including all hoses, hard lines ( dents, dings, rust) lining, springs, cylinders (seepage, leaks, stuck pistons) master cylinder (sediment, leaks). Completely drain and flush with fresh, new fluid. This is standard maintenance for all brake systems, not just 40 + year old brakes.
  19. money pit
    64
    6
    Nov 17, 2017
    That was the plan since the rear end I got had the lines exposed. I plan on replacing all the steel lines and junction blocks and wheel cylinders. The plan is to go to rear discs.
    • Agree Agree x 1
  20. aussiemark
    787
    205
    Nov 29, 2014
    I totally agree but I am probably the worst offender just lazy I suppose, but annual brake fluid changes are a great for preventative maintenance even if you don't use the car the fluid absorbs moisture which causes damage to everything changing the fluid is cheap and easy compared to repairing the damage the moisture can cause.
