1970 383 Challenger Carb
Go Fly
Have a matching numbers 70 Challenger with 383 automatic. Engine trans match vin/tag and build sheet.
Has a Holley on it now. Could that be correct or was it only a Carter?
704406
Shawnigan Lake B C Canada
Could you tell us if it's a N code 383? Is it an R/T? or non R/T? I think the 383 with 335 hp had a carter carb and the base 383 4bbl was a Holley carb. I'm sure 440's were the same, HP had a carter, non HP was a Holley
DetMatt1
Is there a tin tag attached with some numbers stamped on it? Does the car have ac? There should be number stamped on the carb itself too R4368 or R4369.
B5BLUERT
Southeast Nebraska
335 HP orange engines with auto used Holley Carbs
It was the other way around , 1970 383 with 335 HP with auto used Holley carbs. The blue 330 HP engine with an automatic used carter carbs.
EV2RTSE
Exactly right. Basic rule for 1970 383, orange engine = Holley, blue engine = Carter. With the build sheet you can be 100% sure. What's the number in the 'Carb' box?
Go Fly
Thanks for the great info!
I do have the build sheet and found e-bodies.org decoder. What a great tool!
The carb is showing as code 42 and decoded as R4366 Holley and a Holley sits on it now And is an orange engine
The car is a RT / SE. now that finally is starting to warm up in Wisconsin I will look at the cab numbers.
Thanks everyone for your posts!
quapman
Matt, Holleys don't have tags. The list # is stamped on the choke horn.
DetMatt1
Hey look we’ve got new options for liking or not liking posts down on the lower right, this could get fun!:cool:
340challconvert
Parsippany, NJ
Never knew they used Holley 4bll carbs in 1970 on big blocks.
I owned several 1970 BB Challengers over the years and they all had AVS Carters except for the 6pk car.
I thought they started using Holley's in 1971.
The 1971 Challenger N code convertible I had picked up way back had a factory Holley on it. Always something to learn.
Found this chart; may be informative:
Year Engine/Trans Make Style Part #
1970 8 383 S/T Carter BBD 4725
1970 8 383 A/T Carter BBD 4726
1970 8 383 S/T (California) Carter BBD 4727
1970 8 383 A/T (California) Carter BBD 4728
1970 8 383 A/T (Export) Carter BBD 4730
1970 8 383 A/T Carter AVS 4732
1970 8 383 A/T ECS Carter AVS 4734
1970 8 383 A/T Carter AVS 4736
1970 8 383 A/T W/AC Carter BBD 4894
1970 8 383 E.C.S. A/T Holley 4160 4218
1970 8 383 C.A.S. A/T A/C Holley 4160 4369
1970 8 383 E.C.S. S/T Holley 4160 4217
1970 8 383 C.A.S. A/T Holley 4160 4368
1970 8 383 C.A.S. S/T Holley 4160 4367
Matt is correct; the part number listed above is actually the Holley series numbers;
The carb part number for the 4160 series on a 70 383 would have been R4368 and R4369
EV2RTSE
It gets confusing because 1970 440-4v ebodies came with Carters. And there are stories of carb fires with the Holleys that resulted in a lot of them being switched over to Carters early on. My own 383 R/T SE had a Carter on it when I got it but it was out of a 69 Super Bee. I think this list (credit goes to '6bblgt') is the best one there is-
1970
383 manual - E & B-body - with ECS (N95)
orange HP engine 335hp
---------- Holley R4217-A ---------- part number 3418 537 on b'cast 37
383 manual - E & B-body - w/o ECS
orange HP engine 335hp engine on b'cast 084 with A/C & 087 w/o A/C
---------- Holley R4367-A ---------- part number 3418 536 on b'cast 36
383 manual - E & B-body - w/o ECS & with "fresh air" (N96).
---------- Holley R4736-1A ---------- part number 3512 964 on b'cast 64
383 manual - E & B-body - with ECS (N95) & with "fresh air" (N96).
---------- Holley R4738-1A ---------- part number 3512 974 on b'cast 74
383 automatic - E, C & B-body - w/o A/C & w/o ECS
blue engine 330hp
---------- Carter 4736S ---------- part number 3418 538 on b'cast 38
383 automatic - E, C & B-body - with A/C (H51) & w/o ECS
blue engine 330hp
---------- Carter 4732S ---------- part number 3418 540 on b'cast 40
383 automatic - E, C & B-body - with ECS (N95)
blue engine 330hp
---------- Carter 4734S ---------- part number 3418 541 on b'cast 41
383 automatic - E & B-body - w/o A/C & w/o ECS
orange HP engine 335hp engine on b'cast 088
---------- Holley R4368-A ---------- part number 3418 542 on b'cast 42
383 automatic - E & B-body - w/o A/C & with "fresh air" (N96).
---------- Holley R4737-1A ---------- part number 3512 965 on b'cast 65
383 automatic - E & B-body - with ECS (N95)
---------- Holley R4218-A ---------- part number 3418 543 on b'cast 43
383 automatic - E & B-body - with A/C (H51) & w/o ECS
orange HP engine 335hp engine on b'cast 089
---------- Holley R4369-A ---------- part number 3418 562 on b'cast 62
383 automatic - E & B-body - with ECS (N95) & with "fresh air" (N96).
---------- Holley R4739-1A ---------- part number 3512 975 on b'cast 75
1971
orange HP engine
---------- Holley R4667A ---------- part number 3512 848 on b'cast 48
383 manual - E & B-body - with "fresh air" (N96).
orange HP engine
---------- Holley R4734A ---------- part number 3512 849 on b'cast 49
* some sources show the following manual trans carbs w/same part numbers
* 383 manual - E & B-body
* orange HP engine
* ---------- Holley R6191A ---------- part number 3512 848 on b'cast 48
* 383 manual - E & B-body - with "fresh air" (N96).
* orange HP engine
* ---------- Holley R6193A ---------- part number 3512 849 on b'cast 49
383 automatic - C-body
blue engine
---------- Carter 6125S ---------- part number 3512 844 on b'cast 44
orange HP engine
---------- Holley R4668A ---------- part number 3512 830 on b'cast 30
383 automatic - E & B-body - with "fresh air" (N96).
orange HP engine
---------- Holley R4735A ---------- part number 3512 842 on b'cast 42
EV2RTSE
ECS?
CAS?
Yup, CAS, ECS, California emissions, whatever you want to call it : )
Also here's a 1970 Rapid Transit System ad that shows the Holley for the "special high performance" (orange engine) 383 'Cuda (not Barracuda) and Roadrunner. R/T Challengers and Super Bees got the same treatment.
340challconvert
Parsippany, NJ
I got curious so I looked at the original broadcast sheet for my first Challenger back in the early 70's Car was an RT 383 n code car with an automatic.
Broadcast sheet for the carb on this car indicated a 42. As per EV2-
My old RT should have had a holley, but it had a Carter on it at the time I bought it. Engine was painted orange.
dadeo1852
Hmmm, my 1st real car was a 69 Roadrunner I bought new, 383 auto with air grabber, engine was orange and had a Carter AVS, Michigan car. So doesn't fit in any of the above.
704406
Ok as per the 70 service manual.
CAS Cleaner air system.
Consists of special air cleaner, breather cap, ventilation valve, carburetor and distributor. There is about a paragraph in the manual that describes this in greater detail.
ECS. Evaporation control system.
Consists of the CAS system PLUS a vented fuel tank, separator fuel tank, vapour tube, breather cap, enclosed bowl vent valve, a vacuum pressure relief fuel tank cap and hoses. and an additional paragraph in the manual as well
Hope this answers some questions, I don't want to one finger type 2 paragraphs!!!
If anyone wants the additional info just ask
DetMatt1
This discussion is mainly about ‘70/1.
