Auto to Manual trans swap
mezmerized63
Charlotte, NC
I recently took my HemiCuda tribute to a local shop and had them swap out the 727 and install a Tremec TKX 5-speed. Prior to having this done I had no issues with my headers scraping on the ground as I probably had 3 to 4" of clearance, but now the header collectors are only 1.5" from the ground and are scraping on practically everything. I'm hearing that this trans swap could change the pitch of the engine, thus causing the headers to be lower, which is what happened in my case. As of right now, the shop that performed the work isn't being too cooperative so I'm trying to get some information on how to fix this issue and to see if anyone on here has had the same issue during a trans swap. TIA.
If you have any room above the trans you can put shims in the rear trans mount ,
Less desirable is raise the front of the car using the T bars , make sure the car is lifted before trying to adjust it !
Try the shims on the rear transmission mount first! just a 1/4" shim can really raise the back of the engine a 1/2" or more.
Not sure this makes sense. If you move the end of a lever, then any point between that end and the fulcrum, cannot move farther than the end of the lever. The fulcrum being the motor mounts.
Regardless, I'm pretty sure floor mods are required to install that transmission "properly" and the transmission shop wasn't going to cut the floor. There's lot of material on the top of the tailshaft unlike an 833 for example.
Note, I've never done it so I could be wrong but it seems like a simple matter of the floor needing to be modified.
I agree with this.
Did you install a 4 speed hump prior to the tkx swap. It's bigger than the auto hump and required for the swap.
I agree with this.
I did the 727 to TKX swap in my Challenger a couple of years ago. Definitely need the 4 speed hump but no other floor mods were needed in my case. It’s tight in the tunnel but it fit. I’m running 3” TTI exhaust so mine was low with the 727 and about the same now.
It's not the engine that's moving up as much as the TTI headers. You are using TTI headers aren't you?
I bought a kit from silver sport. Tkx 5 speed and installed it myself, I had to change the tunnel. But as far has losing ground clearance I did not. 70 challenger with a 440 and it was a 727 that I also took out. Try calling Silversport they are pretty awesome with helping the customer
Did they change the transmission tunnel to have 4 speed kick out or did they just bolt it in and leave the unaltered auto trans tunnel? This is something you can see just looking at the interior.
The 4 speed kick out will allow the shifter to tuck up into the tunnel out of the way. If they did not do this mod, then yes, the location of the shifter is compromised and everything is going to hang too low.
My own TKX swap on a 440 had no ground clearance issues with TTI 1-7/8" headers.
I think the real issue hear is what the shop did with getting your tailshaft-to-driveshaft angle to cancel out with the driveshaft-to-pinion angle.
The TKX swap does pitch the back of the engine downward but getting the driveshaft angles correct is absolutely necessary to prevent harmonics.
The cancellation prevents the driveshaft from overspeeding and reaching its critical speed (point of deformation).
I hope the shop doing the installation correctly did everything needed.
Check out what I posted for my TKX swap project.
Auto to 5-Speed Conversion (Silver Sport Transmission Tremec TKX) Project Plus
Any update on your engine being tilted downward and reducing your ground clearance.
Yes. The trans won't go all the way up into the trans tunnel and hangs down. this angles the engine down causing the headers to go lower. Surprised you don't have vibration issues now. I did and have tried multiple solutions with all marginal results.
The few degrees of extra downward tilt also can affect the fan clearance at the top of the radiator shroud.
This is why a full fitment should be done even when converting using a factory or AMD 4-speed tunnel hump. Minor tweaking of hump installation to add another 3/8" of clearance to the TKX transmission can avoid issues with too much downward tilt.
