I have a 1973 440/727 combination (213 heads, OEM MH exhaust manifolds, 4bbl TQ carb) out of a motorhome, along with a set of 452 heads and auto exhaust manifolds. It's hard to find information on MH 440's, but the net hp/tq is supposedly somewhere around 220/320. The engine and transmission have 58K miles on them and were reportedly great runners when taken out. I want to get the performance of the engine (8.2 compression) up nearer to 1970 non-Magnum specs, which are listed by one source as 350 hp and 480 ft/lbs torque. If the bottom end checks out OK I'd like to keep it as is and gain the desired performance level by milling the heads (213 or 452's? .050-.060"?) and using appropriately thin, (possibly MP .020" steel shim) head gaskets. Assuming the OEM cam is designed for low-end, I'd even like to keep it as well. Is this realistic, has anyone done it, or does anyone have suggestions based on actual experience? Thanks for any comments!
