My Super Shaker project
6PKRTSE
Had to clear a tunnel ram, dual dominator carbs and 2 fogger kits so I came up with the super shaker idea. Stretched the hood opening length by 3", stretched the base and bubble 3" also. Raised the height 4-1/2" and opened up the nostrils 2-1/2" taller.
6PKRTSE
Hood was just bolted on for pictures. It is all aligned nicely to the fender line and gaps now.
6PKRTSE
Thanks guys. I think the finished product looks and functions well. I like it and think the effort was worth it for something different since I didn't want some pro stock scoop or 6" cowl induction hood.
In testing we learned that the Hemi Shaker cudas would make more power with the bubble removed & would ahve to be retuned with the bubble on , to make matters even worse inserting the grilles into the shaker reduced flow even more , , the bottom line is the shaker restricts air flow to the engine & makes more power without it so anything is an improvement to flow & power , , if the opening are anywhere near stock size you may want to enlarge them .
Good job BTW
6PKRTSE
Openings are more than 2-1/2 times as tall as compared to the stock openings and widen slightly as well.
wayne
SouthEast Michigan
Great work! Do you have room for any air filters or is that not really a concern / more track car?
6PKRTSE
Yes, there is room for air cleaners for street and I run these screens on the track.
Torqueflite
ks
You did a great job! That base had to clear a lot of stuff to work!!
6PKRTSE
Final wash of the year and put away for winter.
