New 512 build planning
Spyder
Far N. California
Last nights first start! Maybe I'm being paranoid but I almost feel like I hear a tap tap tap from the top end. Gotta pull valve cover and check stuff out now, check preload, etc. Maybe it's just the HS rockers that I've been reading make more noise than stockers I'm used to.
Oil pressure was immediate and good. Started easy and sounds smooth, no leaks I saw yet. May get time this afternoon to mess with it some more.
...tried to upload a video but it says the extension isn't allowed.
Ricks72Chlgr440
Sisterdale, Texas
Yeah, you have to send it to youtube, then you can post the link from that youtube video.
Spyder
Far N. California
First drive on the road was a success! Letting it cool down now to drain the oil and cut open the filter for a look-see. Sounds good, pulled hard for the half to three quarter throttle I was doing and then letting it slow down for ring seating, and looks fantastic going down the road. Now all the little stuff so I can put the hood back on and start taking it to town.
I wound up swapping to manual brakes because of vacuum booster problems and they're totally inadequate so far. Either I didn't finish bleeding the master enough, haven't gotten the push rod adjustment right, or something else. Tranny shift linkage is off a little so that's gotta be done, and some little wiring cleanup. During the drive it didn't get over 195, went to 205 when I slowed down and idled into the driveway and shop, ambient temperature outside was high 90s so I'm not too worried about temp, especially since I haven't done any tuning yet.
Spyder
Far N. California
Went out for a little longer drive today and all is still well. A little timing and A/F tuning and it runs better than the first short trip. Bolted the bumper back up, and plan on doing another longer shakedown run tomorrow.
I had misadjusted the shifter linkage, setting it up while in park instead of 1st, which caused most of my problems on the first short drive the other day. I put a second oil pressure gauge in to be sure it's right, and both are running within a couple pounds of each other, and closer to 20 than 10 lbs at 1k rpm idle. Lots of power, pulls hard and smooth, didn't go over 180 degrees today with ambient temp of 92 or so today, and no leaks! Brakes need a little more attention, they're still a little soft after I put new calipers on and bled them, but I'll do a full 4 corner bleed again tomorrow that should solve that.
Just about time to put lots of miles on the rest of the summer, and already planning the winter project list... higher stall TC, new brake lines and fuel lines, and then start working on the Barracuda.
Spyder
Far N. California
Trip to the gas station went well but I totally forgot to take a picture there. I'll get the grill and headlights back in next.
Temp outside is 97, and it stayed at 180 until I did a couple of hard pulls then idled into my driveway and it went to 200. Not worried about that at all.
I'll have some more tuning to do, couple hiccups, a little off idle stumble and it did something funny for a second at about three quarter throttle and 50mph, bogged for a split second, took my foot off the fuel and it went away and didn't do it again. Bugs to work out but real close.
I already feel like I should have gone with a bigger cam. 🤣
Sounds like it's running pretty good! Since it's still breaking in with lots of friction, 200°F is not remotely hot! Not sure about far North California, but in the Sack-o-tomato area, I had similar bog far a split second from time to time and just contributed it to Cali's crappy fuel!
See how it does with the cam that's in there once its fully broken in. If not satisfied, as you know, a big block cam swap is just a few hours job! 😀
Spyder
Far N. California
I'm sure I'll be perfectly happy with it. I'll need to get a new torque converter once I get the bugs worked out, this old Hughes 2k that was in the car when it had the old 440 won't cut it I'm sure, but it's what I had available when I ran out of money. :D
Remember stall speed goes up when torque goes up and your 512 will Definitely make more torque than the old 440, so you might not be too bad off with that Hughes torque convertor!
