Ralph
- Joined
- Mar 5, 2013
- Messages
- 350
- Reaction score
- 71
I have a leak at the rear manifold bolt on the passenger side, all the other bolt heads are dry. Does that bolt go thru an oil passage and need some special compound ?
The manifold is an aluminum Edelbrock DP4B. See the photo.
Advice on how to proceed ?
Last of my leaks on a 5,000 mile motor. First was the oil pan but realize it was so beat up I installed a new one and the leak stopped - installed with the rubber windage tray combo which worked well. Second was the passenger valve cover which I finally sealed up. Small drop at the rear seal but leaving that as is for now.
Hopefully this is the last of the oil leak issues.
Thanks for your help.
