WHIPLASH cams ???????????
youngunss1987
so I have been thinking about putting a new cam in my 340 I seen this whiplash cams sound pretty bad ass on there website but has anyone run them ? and what as been your experience with them any good ???? any suggestions for a cam for 5.1 roller rockers set up ??? my current build is a stock stroke 340 with closed chambered heads 63 cc Edelbrock aluminum heads with flat top .30 pistons with a Edelbrock air gap intake with 3.23 gears for now but 3.91s soon with a 2200 rpm stall my current cam I am running is a Lunati Advertised Duration (Int/Exh): 262/268Duration @ .050 (Int/Exh): 220/226
Gross Valve Lift (Int/Exh): .475/.494
LSA/ICL: 112/108
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1400-5800
The cam I am looking to replace it with is hughes HMC2336AL-7+5
Intake Valve Lift 1.5
Exhaust Valve Lift 1.5
Intake Duration at .050"
Exhaust Duration at .050
Lobe Separation Angle
Intake Closing at .050"
Exhaust Closing at .050
Sweet Spot RPM
idle-5000
33.5° ABC
6° ATC
107º
223°
236°
.512"
.518"
edison1970
Hampstead, NC
I'd like to hear some feed back also. I have a 440 and have been thinking of trying it myself.
They similar to the Lunati VooDoo Cams , there is only so far you can go with a .906 diameter lifter without catching the edge so the ramp can only be so steep , however it is smart to take advantage of the wider lifter to maximize ramp speed & get the valve open as fast as possible, VooDoo & Whiplash do take advantage of the wider lifter instead of just copying Chev grinds onto Mopar blanks . Personally I use Lunati grinds , easy to deal with , Hughes not so much .
71solo2challenger
Wallingford, CT
The Hughes camshaft will make more power/torque but you're going to give up some drivability. The 107 deg LSA will produce a choppy idle and lower vacuum. Not really a big issue, but you should take note especially if you have power brakes. I have a Hughes grind in my 360 and love it. It's a little more aggressive than your whiplash cam profile and my car pulls pretty good. I also run a 2000RPM Hughes Converter (different Hughes), 3.23 gears and 26" tires. A steeper gear/looser converter would help pull it out of the hole better.
youngunss1987
yea I ended up putting that cam in the car I am happy with it so far the only compliant I would have about it is the vacuum ... other then then that is seems to have a better power band then my last cam and sounds really good !
