Kez, welcome back! So glad you are able to get back to working on your Challenger
Time sure does fly by. That '71 is a beauty.
.Time sure does fly by. That '71 is a beauty.
Thanks for the kudos and confirmation on the spare tire! I had pretty much come to the conclusion that my car had the full sized spare and you confirmed that.Just now seeing this thread. Nice job on your car...looks AWESOME!!! I shed some light on the spare tire situation. The only cars that came with the collapsible spare were cars that had 15" wheels.
I would definitely suggest you replace the ignition switch as they cause all kinds of wierdness.Thanks for the kudos and confirmation on the spare tire! I had pretty much come to the conclusion that my car had the full sized spare and you confirmed that.
Torsion Bars installed so car is finally sitting on 4 tires again.
Air Box installed today and starting to work on the wiring harnesses. One friend suggested I replace underhood wiring with new and can reuse interior looms - they look to be in good shape but will test to make sure. Have others done the same thing?
Thanks, will order one!I would definitely suggest you replace the ignition switch as they cause all kinds of wierdness.
Thanks - I did find one through Summit and it did the trick, used some red locktight and snugged them right up to 125 ft-lbs without a problem - I was afraid of cross threading or having spalled threads stop progress before they were seated, but both went in smoothly.The socket for the ball joints is not expensive & is by far the best way to install them .
great job on restoring the car !
I finally got my parts together and installed them - took a couple of pictures for you. The hood trim piece simply bolts on - the leading edge bolts through the holes where the stock trim piece would bolt on, with small bolts installed from the back side. The trim piece also has studs along the rear edge that drop into holes drilled into the hood - these are cinched down with stamped nuts from underneath.Nice work! I’m looking forward to seeing how to mount and the hardware used to install the wide chrome trim on the front..... I have an nos set to install on my 71 project and I have found no parts to install.....
Love EL5 and now I'm wishing I'd painted mine that way! Keep these updates coming
