Righty Tighty
I've been having this issue for a while now, my '74 Barracuda only starts with the turn signal engaged. I posted on FABO because I'm more active there, thought I'd throw it up here as well.
Here's what I've got:
1974 Barracuda 440 six barrel, 727
'70 dash with what I assume is a '70 harness
Pretty much all the wiring in the car is in bad shape, including under the dash
Previously, I noticed the car was getting harder to start with the key, so I went to replace the ignition switch. At some point along the way, I bumped the turn signal lever while having the key turned, and it started.
Long story short, after following some advice, I unwrapped the under dash harness to inspect for damage/obvious shorts. Found nothing. Since I planned on replacing this dash with a '71-74 dash anyway, I'm going to start clean with that one. In the meantime, I'm going to try troubleshooting this one because I'm curious as to where the problem lies.
Stay tuned...
Stay tuned...
![IMG_20230430_113247426[1].jpg IMG_20230430_113247426[1].jpg](https://www.forebodiesonly.com/forum/data/attachments/101/101406-34723c734b5a744ea15b0b01f1e49152.jpg?hash=NHI8c0tadE)
