michael bucklew
- Joined
- Aug 24, 2019
- Messages
- 334
- Reaction score
- 44
on 3rd ballast resistor. new one installed when hooking up wiring harness. no good. was very hot. tested no good at store. #2, first start on the rebuild. timed and adjusted carb. spent part of day starting engine.Been I shop for about 10 days everything was fine. Ralley gauges worked. tried starting motor today, ran for a while and quit. had the same symptoms as first resistor , fire, no run, very hot to touch. now, no start. can a non ballast resistor coil be used---?? first start problems. Year old battery failed, no good--fuel pump, not pumping--ballast resistor no good. had good first start day--all parts replaced by store..anybody else purchase bad parts?? Michael '71 challenger
