Front disc installation
gran coupe john
Ohio
My 71 barracuda has 4 drums original. What suggestions about converting front with disc brakes. Is original equipment available? Or should I go with aftermarket? Just don't like the 4 drums the way is stops.
There is a list of brake fixes and issues here.
John,
There are complete aftermarket disc kits available that will work well. I would recommend doing fronts only.
One important note: from what I understand, most of the aftermarket kits are based on the 72-74 E-body front disc brake setup. They will fit on a 71 as a complete kit, but in the future you have to remember 72-74 if you want to change parts. If you want original 71 setup, you have to find the parts yourself (spindles, brackets, caliper, etc.).
FMJ / Volare , 5th ave bolt right in , obviously you need a different master + a proportioning valve
Scarebird has some very cheap options using easy to get parts
Dr Diff also has Mopar solutions
What would be ideal for me would be original 71 front disc brakes. But afraid of the cost. I haven't done any research on after market. Just need more input.
I would be more afraid of not having enough braking power when needed. If you read through the the Brake issues that I posted. There is a lot of information there from others.
As said by Chryco Psycho
I think that is the most practical and inexpensive way. If I recall the is a bushing option for drum spindle to use the rotors. That is if you want to retain the 14" wheels.
If you go with the larger rotors you need 15" wheels.
Disco-O--Tech is the Mopar Bible for disc upgrade.
Used that to do my swap years ago.
Unfortunately good used spindles are gone, but aftermarket is available.
And everything else needed is available at local parts store or RockAuto.
