Oystercopy
- Joined
- Jul 25, 2019
- Messages
- 129
- Reaction score
- 40
OK, so I replaced the original Carter with this Edelbrock. The linkage worked perfectly fine for the Carter, but as you can see in the photos, does NOT match up with the Edelbrock. The carbs were identical otherwise, so I don't know what happened. You can see that I have a Zip Tie holding the two together, but obviously, want to fix that. Anyone have any idea what I need to do here? Got the carb from JEGS, if that matters... thanks in advance!
