Key on 6.02, Cranking 7.92-8.02
After thinking about it. It did start up before I put the dash in with the old wiring harness. The engine, trans, front & rear light harnesses are new. I might have a electronic somewhere in the old harness??
Tried the ammeter method... still the same results. I check the voltage at the positive side coil- 5.6v, at the ballast resistor- 5.6v, at the connector to the bulkhead- 5.6v, from the bulkhead to the ignition switch- 5.6v, at the ammeter- 11.35v at positive & negative side. on the voltage regulator and alternator field Im getting 11.35v.
I have two ecu and tested the ecu bolted to the firewall and the ecu not bolted to the firewall.
The one bolted to the firewall has the first results.
Key on & ECU connected:
1) 5.6v at the coil positive.
2) 1.5v at the coil negative.
3) 12v at the Ballast resistor
and the one not bolted to the firewall has the second results
Key on & ECU disconnected:
1) 12v at Coil positive and negative posts.
2) 12v at the ECU pins where applicable
The ecu that wasnt bolted down, I pressed against the firewall and I still had 12v until I moved it to bare metal and the voltage went back to 5.6 volts.
I also found that the (dark blue/white line) wire from the alternator to the bulkhead to the ignition switch, key wrng buzzer, oil pressure indicator, brake wrng lt was fried.
I repaired the two wires but Im still getting the same results
