73 barracuda rally dash wiring question.
Here is the red connector I think you are talking about... Do I supply volts to that red connector..looks like the red wire go to the clock like you said... I\nHave this light green wire?I'm not sure about\nAnd a black wire connector... And it looks like a yellow connector a pink wire and a white wire with brown plugs...
correction, that's "key-switched" on that accessory tap
Yes, remove the harness accosiacted
Thank you very much.That is so helpful... I appreciate your time.. So I should be able to remove that harness just above that green wire in the picture you pointed out that's associated with the AC stuff.\nSwap those two plugs out correct
Yes, you can remove that A/C harness completely, transfer the indicated blower fan power connector to the main harness, there is another connection near the blower resistor pack to disconnect, the connector on the main harness there then goes to the non-A/C resistor pack directly.
The one wiring harness in the first pit is tape to the dimmer switch... As.
Far as the wire coming out of the fuse box area can I just go all the way in and unplug and take the spade clips out for those wires?
Now separate the fuse box from the bulkhead connector and remove the two Packard terminals on those two remaining A/C harness wires from the bulkhead connector.
Second pic is the rear body harness connector.
Okay that is disconnected thank you.. I believe this is all I got left.. Is this where the rear body harness connects?Is that what you said
Got it... Outstanding.
Thank you for your patience..
Hopefully the last questions l o l.. First picture , the yellow two wires , single plug and the orange , black and red with a white tracer.. Second picture blue wires white plug. Last picture, the dark green and the light green goes to the non. AC resistor thing, I believe. Do\nI need to do anything with the other 2 relays.Maybe a key chime , and something else...
Door switch ground circuit, would connect to the optional ignition switch light delay relay and harness if equipped.
Dash light circuit
Radio power connector (accessory circuit) with dash light (orange)
Seat belt waring light
Goes to the blower resistor, non-A/C. Should be an additional single connector on a brown wire there as well.
Seatbelt warning system relay (3-wires) and buzzer (2-wires)
Dash light circuit
Ty ty
Dash light circuit
I Did not find a brown wire or brown plug.. I did notice that the heater box has a plug on it that goes to the metal part of the heater box... I'm thinking maybe that the ground strap ground stew.The motor mounting bolts and grounds that resistor I don't know
Yes it does
I have a question.Maybe you can answer when installing the dash back in..I did not remove it originally.I noticed two studs that are for the steering column on the 73 barracuda..when the dash is put back in place.Are there any nuts that goes on those long Studs for the dash..or just the two for the column...i know there's one bolt on each side of the dash and four at the top by the windshield. To hold the dash in..Thanks again.
