Help needed with carb ID and what kit(s) needed to rebuild.
KVB
Still figuring out a couple things and I haven't had to pull anything back off the carb --- it seems to want to run well on test drives well....I think this carb rebuild is a success!
The cold starts seem fine - (two pumps), hot starts are still a ***** - advance issue?????
The choke is locked out (more likely for a reason).
NO carb leaks (TY ALL!!!!)...holds steady 180ish coolant temp, while I idled/opened/goofed around with mixture for 30-40 minutes). 6 psi fuel inlet psi, .5 out mixture screws seemed best for idle and I still reek of spent/unspent fuel.
#71 jets, floats set 1/4 inch below site hole.
It seems to high idle around 1100 after a good run through burn (6k rpm)...then settles to 950 and will idle little lower eventually.
First cold start after carb rebuild.....success!!
Block the heat cross over port through the intake , 440 uses FelPro 1215 , 383 uses 1214 . You could also use a Cool carb spacer or the Holley alum one to reflect heat
Ths will stop the fuel boiling in the carb which is causing flooding / hot start issue , this fuel is nothing like 1970 fuel
KVB
It's shimmed with 1/4ish alum plate, hardware and an air-gap intake. 340 cid, it's fickle so far. Could be crap fuel....plug burn next???
Ok so no heat cross over to block , it would help to extend the plate under the fuel bowls as the Holley pate does
